Edough13
Bashing, Speed running and family!!
Hospitality Award
- Location
- Northern California, USA
- BigRock 4x4
- Granite
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Typhon 6s
- Vorteks
Definitely a fine line to walk! I also want to thank you brother for all the encouragement and keeping the competition alive. I'll be 100% honest with you your a big reason I not only started but have pushed for higher PB's. When you hit 112 it pushed me as I was only at 114 and wanted to do better so I tried 8s for my overall best of 125 and only because of you were so close keep it up brother, I know if I've gotten to where I'm at you'll be up there soon as well. As you said have patience work out the kinks and it will happen!What a crazy weekend it was. Thanks to so many on the forum including @Mr.Duke, @K-BASH, @LibertyMKiii, @jondilly1974, @Jimbobjr, @Grimbles, @Hammer Down, @The Donut Man and countless others. So many mistakes were made by me in the pursuit of higher speeds, but as of last night, I've got many sorted out. Recalibrated the radio and changed many settings. Set up the esc better with Castle Link. Dropped down the pinion on the motor and so many other little tweaks. Also got a great lesson on how to use the Castle Link software more efficiently. Now I haven't run it full out yet with all the changes, but after some good test passes on Saturday, definitely headed in the right direction......again. To any and all who want to get into the speed run game, this is not for the weak of heart, or light of wallet. It is a gruelling process to inch forward a few miles per hour at a time. Trying to make huge leaps will crush you, as I have recently learned. Reading or seeing what someone else has done and immediately throwing those set ups into your own rc, is a recipe for disaster. Take your time, and changed things slowly and steadily. Learn what works and what doesn't, and try to keep as much detailed information as possible. Kudos to those who are making headway in the speed run game like @Edough13, @rotauq, @Notoriousone, @ABabyEater, @phildogg and the others already mentioned above. Respect to you all for playing a game where the stakes are so high.
