SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
Agree. And specifically the position of these wires of this esc is such that it may rub against the servo. The integrity of the soldering may fail and worst case scenario, you lose esc power while bashing. Epic fail.Then you will likely have to reinforce the wire beyond the solder joint as it causes a stiff spot in the copper wire which will work harden and break as the wire moves/vibrates when bashing.
Might have to consider a new esc. A light delicate soldering job nonetheless may reduce wire rigidity. Fine tip. Lead solder vs silver if possible.More workable. No pre-tinning. Load the tip lightly and hit the wire. Quick. You have one shot at each wire. Liquid tape is your friend. Mess one up. Buy a new esc.
