RCROD
No worries, as Mboss has a Nero (dual battery trays).I looked at those but at 51mm wide they might not fit so im interested to see what happens. If you do make em fit they should be a decent choice battery.
Not sure if you are still looking, but here's a link to the Power Hobby Lipos I'm using (5200mAh, 50C constant/100C burst). They measure 138x46x27.5mm & weigh only 350g each:
https://www.ebay.com/itm/PowerHobby...413578?hash=item3d5abe1c4a:g:Yc4AAOSwIJlaMcoG
These Power Hobby Lipos also look good. I may try these as my next batteries. These are the same as my 50C, but 75C constant/150C burst rating & weigh just 1.5 ounces more. Also, no problem to fit, as only 2.5mm taller than the 50C, measuring 136x44x30mm:
https://www.ebay.com/itm/Powerhobby...603828?hash=item2a878a2434:g:QgkAAOSw2iNZZDN4
Power Hobby also have many different capacities 5200mAh, 6000mAh, 6500mAh, 7600mAh, 9000mAh. They also have 50C, 75C or 100C ratings, plus even the new HV (high voltage) Lipos. However, you will need to check any of these battery dimensions?
I've been happy so far, as my 50C Lipos have great power and punch, very light, small dimensions, and no problems to report yet. My only complaint, the wires are only 12gauge.
