- Thread starter
- #61
Thanks to this thread. I was able to get a cooling solution in time for the warmer weather around the corner and throw on larger pinions. I also 3d printed a fan shroud for the velocity stack. If I needed, I have some 40mm server fans ready to be mounted.
That's awesome! I'm glad this thread was helpful.
![Smiling face with smiling eyes :blush: 😊](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60a.png)
![Sign of the horns: medium-light skin tone :metal_tone2: 🤘🏼](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f918-1f3fc.png)
I will be building a similar set up. I will have to see if I can get my cousin to print me off the adapter plate. I will be running 34 pinion : 34 limitless spool. I wonder if this can keep the temps low enough. What temps have you seen?
I'm not sure if this setup will help keep temps down on your setup. I say that because I'm not familiar with running that large of a pinion. I understand that you'll be running a smaller spool, but I'm not knowledgeable on the subject enough to know the heat effects of a setup like that. Sorry I couldn't give more insight.
The temps I was getting were below 180 degrees, but the exact ones are somewhere in one of my threads. But please keep in mind - my driving style could be the reason for keeping temps down. I feather the throttle Vs. constantly holding down on it. Good luck with everything!
