I will try with a dremel. ThanksUse a dremel cut a line in the middle of the screw , and use a flat screw driver to open it , another option is an round extractor but they don't always work , last option I would use is a 10mm drill bit anti clock wise with pressure , once it's out change the screw to a titanium or ss screw as the heads a stronger
Thanks for your opinion, I will buy a drill bit for metals. I hope these work, I have a steering problem, which does not allow me to use the carThat aint nothing Like dude above me said 10mm drill bit clockwise best and only way of removing it
Thanks for the science slick2500. But we are more like mechanics than engineers. Interesting stuff. When I did 1/12 scale carpet we switched out all the screws for titanium, for lighter weight, not strength. Good point.Titanium and Stainless steel are not stronger than steel.
The minimum ultimate tensile strength of the Grade 12.9 Metric Hex Head Bolts is about 1242 Mpa or 180,000 PSI, making them the highest grade of bolts produced.
Commercial (99.2% pure) grades of titanium have ultimate tensile strength of about 434 MPa (63,000 psi), equal to that of common, low-grade steel alloys, but are less dense. Titanium is 60% denser than aluminium, but more than twice as strong as the most commonly used 6061-T6 aluminium alloy.
Most every stainless steel screw available for rc is made from Ferritic stainless steel.
Ferritic Stainless Steel
(Between 15%-18% Chromium) - Ferritic stainless steel has a tensile strength of 65,000 - 87,000 PSI. While it is still corrosion resistant, it is not recommended for areas where corrosion is likely to occur. This material cannot be heat treated. Due to the forming process it is magnetic and not suitable for welding. Ferritic grades of stainless include: 430 and 430F.- Below are some of the many bolt grades of stainless steel that we carry.
18-8 Stainless Steel:
(18% Chrome, 8% Nickel, .08% Maximum Carbon) - 18-8 Stainless refers to 300 series stainless steel. 303 and 304 Stainless are the most commonly listed grades, the standard grade for stainless fasteners. They are corrosion-resistant and durable. They are often used in marine applications in freshwater environments but will not work as effectively in a salt-water environment as 316 stainless. Stainless alloy resists oxidizing and rusting, however it can tarnish over time. Equivalent to metric A2 Stainless Steel.
This is true. If Im not mistaken the main reason ppl use titanium or SS screws is corrosion resistance, not strength.Titanium and Stainless steel are not stronger than steel.
Greywolf,This is true. If Im not mistaken the main reason ppl use titanium or SS screws is corrosion resistance, not strength.
And both are lighter as well.This is true. If Im not mistaken the main reason ppl use titanium or SS screws is corrosion resistance, not strength.
