scottyzinsd
I am having issues with my center differential slipping. I am using the aluminum blx case. I actually opened a brand new one and it still slips. I opened a new gear set and it still slips. The only thing i haven't tried to replace is the metalposts that go into the differential. Could thise cause slippage?
I also am having issues with my rear diff. I replaced the bearings on the housing. I didnt push the gear teeth all the way in, so there was play going back and forth. I corrected that and now i am having the same issue with the rear diff case. The gears slip when i put the diff together.
