Wow! $4.00 proline is $50-$60 ?
Yup, for that kind of accesoiries I go cheap.Wow! $4.00 proline is $50-$60 ?
Gunmetal is the same as the RTR option wheel. Gunmetal has been on B/O for like a year. Good luck finding them when you need to replace them. You may even struggle to get the red or greens. I did. I was lucky enough to get an extra gunmetal set from RCTruth. How he got them I will never know. There was some rumor that the Gunmetal wheels don't have rounding out issues. I don't believe that. What's the difference, grey Color makes it stronger??? Not. I also noticed the side battery velcro strap will rub the spur. Bad design. Gets chewed up easily. Should be a shroud in that area to protect. Just my observations.They are the same, my photo is a bit dark... part numbers from the exploded view:
With two zip-ties, one on eatch side, through the mounting hardware and a bar of the rollcageHow did you mount the light bar?
How did you figure out where to drill the holes? Did you use self tapping screws?Not much has changed, but I drilled four holes in the esc plate and bolted it with screws.
Looks much better!! ?
Thank you @BashingBrian for the tip!
Made a template using paper and a pencil from the bottom holes on the esc.How did you figure out where to drill the holes? Did you use self tapping screws?
No worries, no need, I went ahead and ordered a m2c plate. ?Made a template using paper and a pencil from the bottom holes on the esc.
Then I measured/checked the position of the esc to make sure it would fit
After that I used the template to make the holes in the esc plate and I used the 'standard' screws to bolt the esc on the esc plate.
I also checked the depth of the holes in the esc, to make sure the screws weren't going to deep. I think I used some rings because the screws were a bit too long and one hole was a bit off, so I had to make it wider...
I think I used AR721308 as screws
If it helps I cam take a picture tomorrow, since it's already a bit disassembled for cleaning
What size are those bearings you used to replace the steering bushings? 6x10x3 ?Steering bushings have been replaced!
Needed some heat, but the top screws came off eventually ?
View attachment 105809View attachment 105808View attachment 105806View attachment 105807
Yup, from a set of Jim's bearingsWhat size are those bearings you used to replace the steering bushings? 6x10x3 ?
Which pinion have you settled on 20t or 22t....just installed the max6 combo on my mojave...was in my Kraton exb...but too much torque...so placed in the mojave. Have 20t on now ....but curious on 22t performance.I decided to change the diff fluid of the center diff to 200k and placed the battery tray to the original position.
To prevent the spur from touching the battery strap I used some lexan from a Stampede body, the wheel arch make a perfect fit: (still some trimming needs to be done)
Fun to run isn’t it!?
Could you link me where to get the scorched RC Mojave fenders? I’ve been having a hard time trying to find them today. Thanks!Hi there!
I've got a feeling a new release is near.... so I'll start my build thread by listing the parts I'm going to be using for the Mojave EXB
The Mojave EXB roller is the only component I haven't ordered yet, lol
1. Mojave EXB - Received
2. Leopard WP-BL-160A ESC - Installed
3. Hobbywing 4985 1650kv motor - Installed
4. YeahRacing heatsink with 2 hudy fans
5. Savox SW-1210SG servo - Installed
6. Sanwa RX-481WP receiver - Installed
7. Scorched RC Mojave inner fenders - Installed
8. Bearings for the steering - Installed
9. 800cps shock oil - Installed
edit: added no. 8
edit2: added no. 9
edit3: changed motor
