- Felony
- Kraton EXB
- Senton 3s
When he got stuck in the 50s..When did you bump up the kv?
Yep that's what I was gonna do, prolly apita to build it and get it right!!Thanks! I'm running Elevens but I've burned off all the tread! I ended up buying the HR Slipper eliminator! Couldn't get a spool right.
Running 27/36 mod 1 gears currently! Changed motor /ESC when I couldn't keep it planted at low speeds!
Makes sense, I don't see the 50/32 getting us close to 100.Yep that's what I was gonna do, prolly apita to build it and get it right!!
If you've still got the 150a esc available try it with that 3900kv and 20/50 gears. Earl Moorehead YouTube channel did that with the Vendetta to get 100+ Myself I'm stuck at 99, vendetta body on infraction mega chassis. 150a 3150kv 22/44 gears. No inside plastic diffuser, tightened shocks down on the rear and changed rear camber. No diff fluid changes made. Still hitting the amp ceiling so gonna try changing the aero slightly with body post change at the rear for less drag and then regear to 20/47 maybe go 3900kv.
Sounds fast!Ok guys.... I'm about to @K-BASH the sheot out of this thing! I ordered a set of 3s links from JRC before it arrived thinking it would have plastic ones like the rest of the megas so I'm about to use these as shocks. Previously dubbed by me as the @K-shock eleminator. Just got some Fd up family news while writing this so it won't be tonight. Update soon.
I hope all is well!Ok guys.... I'm about to @K-BASH the sheot out of this thing! I ordered a set of 3s links from JRC before it arrived thinking it would have plastic ones like the rest of the megas so I'm about to use these as shocks. Previously dubbed by me as the @K-shock eleminator. Just got some Fd up family news while writing this so it won't be tonight. Update soon.
How did you mount the 150A ESC in there? Is it just Velcroed to the receiver cover?Not impressed today! I know 26/57 gearing is not for speed but I was hoping to Crack 40+. 2050 motor never even warmed up and it was fun raising "HELL" in one bay of the shop! At least I know I'm looking for a 40sumpin' bashing gear now.
Bay bash!
If it's a 60000rpm max motor it'll be good to 15.3v till it overrevs.just watch motor temp
So help me out here, am I looking for Traxxas mod 1 gears and the Traxxas spur for the HR eliminator or the HR ones.. lil confused on what I need for the slipper eliminator!?Thanks! I'm running Elevens but I've burned off all the tread! I ended up buying the HR Slipper eliminator! Couldn't get a spool right.
I'm in the same place you are. I'm not sure of what I need to pass the 50T/32T 0.8 options.So help me out here, am I looking for Traxxas mod 1 gears and the Traxxas spur for the HR eliminator or the HR ones.. lil confused on what I need for the slipper eliminator!?
I figured it out, what do u need help with!?I'm in the same place you are. I'm not sure of what I need to pass the 50T/32T 0.8 options.
The parts we need to purchase to make it work.I figured it out, what do u need help with!?
