Hobbywing Xerun XR8 Plus Brushless ESC/G2 Motor Combo (2250kV) PROBLEM HELP!!
Lbizzle
North Florida
  1. 4x4-Mega
  3. Typhon 6s
The problem is when I hit a jump it dies... like no power to the motor at all so I can’t correct it mid flight. It lands and wreck most of the time now. So I experimented and it does the same thing if you just drop the car on it wheels from 4 feet of the ground but you can still steer it just lose power to the motor. If you wait 15-30 second it returns to normal all the wires are tight no loose connection any where. You can drive it all day as long at you don’t hit anything even the slight bump with shut it down but every time you still can steer. So any idea what’s the problem is????
This ain't good, someone else chip in. Maybe the sensor wire to add onto my other post?
Have you tried a different receiver maybe it got wet and now has a short when jarred. Interesting?
I have the Xerun xr8 plus with the blx100 brushless 3200kv motor in my granite mega 4x4 that has been completely converted to Blx.
Esc settings:
1: fwd/rev/brk
2: Auto calc
3: auto cut off volt
4: esc therm 105c/221f
5: motor therm 105c/221f
6: Motor rotation CW
7: bec voltage 7.4v (Savöx SB-2274SG HV 7.4v brushless servo)
8: brake force 50%
9: reverse force 25%
10: punch level 9
11: drag brake 0%
12: coast 0%
13: neutral range 9%
14: drive mode Hybrid
15: boost timing 3deg
15t pinion 32p/ stock 57t spur 0.8mod
Integy dual fan motor heatsink
BLX differentials, BLX adj motor mount, BLX slipper assembly.
Also played with 4s and handles quite well.
Hope everything has been going well for ya ??
