I wanted to mount my Hobbywing XeRun XR8 140 / 880 amp ESC to my Senton 3S but it's too wide to fit in between the two lid screws. Originally I had to mount it sideways in between the screws to fit but this led to part of it sticking out from the lid which meant it did not make full contact with the two sided tape and also forced the ESC control wires to be bent against the steering servo. I know I have seen a few people mention how mounting a aftermarket ESC to the 1/10 chassis can be a bit of a pain.
This ESC adapter plate allows for both the mounting lips of the radio box lid and the mounting screws to fit fully under the surface of the plate giving you a large, even flat surface to mount a aftermarket ESC to your 1/10 scale Arrma correctly. This plate simply fits on top of the receiver box lid and screws down with the original screws. I believe all the 1/10th scale Arrma vehicles use the same radio box set (or at least the lid anyway) so this should fit any of the 1/10 scale vehicles, please let me know if this is not correct. The bottom lip flares out to give it extra support around the mounting holes and I made all the holes with a slight oval shape to give a little forgiveness with printing tolerances. If this is a problem that has been bugging you and you have access to a 3D printer (or know some one who does) feel free to grab the .stl file here ---> https://www.thingiverse.com/thing:4637286
