Take a Kraton, put a 5cm longer chassis, SCT wheels, front and rear SCT bumpers and SCT body and you will have a 1/7 SCT.
So take a Senton and a 5cm longer chassis?Take a Kraton, put a 5cm longer chassis, SCT wheels, front and rear SCT bumpers and SCT body and you will have a 1/7 SCT.
I might be wrong, but the suspension travel seems much longer than regular.Take a Kraton, put a 5cm longer chassis, SCT wheels, front and rear SCT bumpers and SCT body and you will have a 1/7 SCT.
No, the Senton is more close to the Typhon, they use the same chassis plate. The Kraton has almost the same size as a 1/7 SCT with only 5cm less on the wheelbase. You just need to put rims with different offset because out the of the box the Kraton has more width, only because wheels have more offset.
Compare the dimension of the Traxxas UDR and the Kraton, The Kraton is shorter from 5cm and width is bigger, then watch the rims.
UDR : wheelbase 420mm, width 345mm
Kraton : wheelbase 377mm width 461mm
Senton : wheelbase 328mm width 295mm
So, what your telling is: the 166mm difference in width between the Senton and the Kraton is due to offset in the rims..
That’s the old 2wd version
The ATX100 is still a better radio than the STX2.2wd n nimh battery what a joke. Glad they got rid of pos radio
Hehehe didn't see that post☝?
