- Maryland
- Infraction
- Limitless
- Mojave EXB
- Senton 3s
- Talion
- Typhon 3s
- Vendetta
Well there’s just no one that’s pushed these Rlaarlo motors yet. They will hit their limits for sure just have to find where.How would you expect a 3660 3900kv like that to perform against Castle’s 3660 6400kv?
I’m curious if the huge price difference is justified.
The castle 6400 is a capable motor but you need to be good at gearing it correctly.
One of the other runners on my road, Demarco Kane, has done 167mph on a single Castle 6400 on a 4s Onyx pack and a Mmx8s in his ak917.
The motors in these cars as a dual motor version won’t be the limiting factor it will be the esc’s. Since you can’t fit two Mmx8s esc’s in the car your limited in what will fit. I’m running the 1/8 mmx 6s esc’s in my tp motor dual build that are good for 220 amps out of each one but I’m at 150 amps on my 127mph run. So I expect to hit their limit before the motors are even close to being maxed out. I do have a second set of esc’s coming that have been “hacked” if you will to remove any cutting or heat cutoff errors and just go until they blow. So I’ll try them as well.
On the same subject with the esc’s I expect that the rlaarlo ones will at some point cut out on me pushing the rtr car as I am. I’ll know soon enough because I’m going to be running 4s soon. I have some custom sized packs coming to try
