Finally got my Tekno stand-offs in the post today and after fitting the shocks, I noticed that the rear of the truck looks very low.
The shocks are the correct way around (longer set at the rear). And I'm running Yellow 80mm Front / Green 90mm Rear.
At the front, and with the weight taken off the shocks, the wishbones hang downward. This settles into a nice, flat stance once the sag has been taken up.
However, at the rear, there is no sag. With no weight on the shocks, the wishbones are horizontal, caused by the shocks being shorter than stock. With weight on the shocks, they need the preload adjusting significantly to settle flat. Otherwise it drags its behind.
Are you Tekno shock owners experiencing the same thing?
