- Notorious
- Talion
- Typhon 6s
Got a 2 inch extended Fast Lane Machine chassis and brace kit for my Stampede, making the new wheelbase 12.63 inches. I also have the FLM aluminum transmission with a 7075 aluminum sealed diff with larger bearings than the stock diff that I bought and installed a few weeks back. It is a nice improvement over both the stock and Drag Slash transmissions, much quieter and handles 4s easily. Made a custom esc mount from kydex, looks like it will work and hold up well. I cut the RPM Slash front bumper a little shorter and drilled new holes so I have just enough room in the front for some 30g weights to help keep the front end down. Long screws and locknuts allow me to add or remove them fast and easy. With all 5 weights and my heaviest belted tires the whole rig weighs 6 pounds 10 ounces without body or battery.
Got it out for a bash today, love this thing! The added length with the front weights keeps the front end down enough to keep some speed over rough terrain. I could tell the turning radius was a little wider, but not an issue with 4s power on a 2wd to just whip it around. Jumps nice, nothing big today, but little 2-4 foot jumps over a dirt hill were smooth and balanced.
Electronics:
Hobbywing Max10sct 120a
Spektrum 3668 2400kv motor
25kg servo w. Kimbrough HD servo saver
X6GF receiver
Front:
RPM Slash front bumper (RPM80592)
RPM bulkhead (RPM73752)
RPM wide suspension arms (RPM70662)
ST Racing hardened suspension pins (ST3640BK)
Arrma 4x95mm turnbuckle (ARA340175)
Team Asc 4x50mm turnbuckle (ASC89526)
RPM Rod Ends (RPM80512)
Atomik RC caster blocks (4128GM)
Atomik RC front knuckles (4127GM)
Traxxas front axles (TRA3637)
Tekno RC 12mm 7075 aluminum hex (TKR1654X)
Hot Racing 17mm hex adapter +10mm offset (HRAWH17HT01)
Shocks
ST Racing shock caps (ST3637S) & bodies (front ST3765XS & rear ST3766XS)
Traxxas GTR shock shafts (front TRA2765T & rear TRA2656T)
Hot Racing Progressive Springs (front HRASLF48FS261 & rear HRASLF63FS261)
Chassis:
Fast Lane Machine Stampede 1/8 scale chassis and brace kit (FLM22360)
Fast Lane Machine 6mm front shock tower (FLM25000)
ST Racing 6mm rear shock tower (ST9418S)
Custom kydex ESC/receiver box mount
Traxxas receiver box (TRA3628)
Rear:
Fast Lane Machine aluminum transmission & 7075 sealed diff (FLM20200N)
Tekno RC drive cups/driveshafts/hub carriers/axles/bearings (TKR1951X & TKR2210)
Traxxas HD rear arms (TRA3655X)
T-bone Racing bumper (discontinued)
The 79 Ford is a shelf queen shell, for bashing its the blue 89 Silverado.
Electronics:
X6GF receiver
Front:
Shocks
Chassis:
Rear:
