McClain210
I store my trucks on a plastic shelf. I was pondering the idea of placing them on stands to elevate the wheels and suspension. Do any of you guys do this or am i overthinking things?
Especially if you have RPM arms. I once had a set of RPM arms bend and stay bent from sitting on the wheels too long.Best to do this. Relieves stress on the arms and tire flat spots.
How tall of a yoga block do i need to get notorious/kraton wheels off the ground?Their your trucks, you can be as “OCD” as you want…
I put mine on yoga blocks.
For the 6s, a standard size works fine and the 8s rigs I use two taped together on edge.How tall of a yoga block do i need to get notorious/kraton wheels off the ground?
I've heard boiling them will being them back to life.Especially if you have RPM arms. I once had a set of RPM arms bend and stay bent from sitting on the wheels too long.
Do you happen to know what stores would carry them? Going to pick two up tomorrow if i can find themFor the 6s, a standard size works fine and the 8s rigs I use two taped together on edge.
Amazon.Do you happen to know what stores would carry them? Going to pick two up tomorrow if i can find them
Walmart has them often. They also have yoga bricks, which I prefer as they are heavier and don’t slide around as easy.Do you happen to know what stores would carry them? Going to pick two up tomorrow if i can find them
My local Wallyworld only has the thinner 3” blocks. (Perfect for my on road rigs) They also have standard size cork ones.. are those considered “bricks” ?Walmart has them often. They also have yoga bricks, which I prefer as they are heavier and don’t slide around as easy.
I use the standard wall shelf brackets without the wood… I put fuel line on the brackets. Don’t mind my messy corner… ugh. Hahaha
Apparently you and I have different definitions of messy! my corner looks like an episode of hoarders!
