- Location
- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
- Thread starter
- #41
So with thanks to @SamTheExplorer for informing us that this part exists, I received the front hinge block from ScorchedRC
I think the original Arrma part is a real weak point in their new basher bumper that comes on the EXB, hopefully this part will make it the best bumper setup you can use..!!
Below you can see the original part and the ScorchedRC part..
So, we're finally here at the electronics and I chose for this build ........ the MMX8/1717 combo..!!
( if it turns out too heavy I'll use a HW Max8 combo or stock BLX system that I've got lying around )
Went with a 22T pinion as it worked fine with my Kraton and the Talion has slightly smaller wheels.
As always thanks @Mr.Duke for the dual fan mount
Thought I'd try out the B-link as I've seen it on a few builds here on the forum..
Below you can see where I had to notch the rear wing so it would clear the M2C tower..
Had some leftover kydex from another build so decided to make some dirt guards..
Nearly the end
Nearly the end
