SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
Servo tape, i.e two way tape has been used for decades in this hobby. It is not a new concept. 3M Automotive adhesive Two sided tape makes the best IMHO. I believe RPM may make a Castle ESC mount. Not sure for your specific ESC. There is nothing wrong with using tape and Nylon wire ties together to strap the ESC. Hard bashing will require both. Silicone adhesive is fine also. The ESC will be removable if you need to remove it. Bashing Hard requires good mounting however, and an ESC mount alone that you are referring to is NOT the most secure in any event. Been there. It may appear weird to use servo tape, but you admit you are new. Some things accept and move on. Experience will dictate and questioning is fine. Servo tape is fundamental in RC for the most part.Hey Ricky,,,,,it aint rocket appliances.......
lolz...
I hear ya bro, it’s weird they expect tape to hold that down.....I’m new to the hobby and this two sided tape thingy has me baffled.
good luck,,,,maybe some tie wraps are the ticket, as well as tape. Gorilla sells some good stuff, it’s called mounting tape.
cheers,
kev
