- Location
- Bozeman, MT
- Felony
- Granite
- Infraction
- Limitless
- Kraton 6s
- Nero
- Raider
- Senton 3s
- Talion
- Typhon 6s
- Vorteks
- Thread starter
- #21
Just use a sharp blade or pick and pull them off. They are pressed in.
Pretty much this. I used a dental pick with a 90° bend in the end. Be careful with the seals, as they are often super thin sheet metal with a rubber coating. Work the tip into the bearing around the edge of the seal, unseating it from the bearing applying slight pressure away from the bearing, and gently slide it around the edge until it pops loose. To reinsert it, line it up and just press. My thumb fits over almost all the bearings (except the inner hub bearings), and I have found just squeezing will usually push the seal back in pretty evenly.
