Replaces the steering bushings, top and bottomOK getting closer to putting this back together finally. Just waiting on a few more parts to arrive.
What do these little tiny bearings go to? Old bearings next to them for size reference.
Also I saw mention of a flange bearing in another post, which I saved the info on in case I will need it in the future, but I don’t see that anywhere either? What am I missing?
Should be fine. It's just to help reduce the wear on the pinion and ring gear. I use a syringe to apply it right to the teeth, so I don't have a ton of it to clean later.F -it!
I welcome your responses on recommended greases, but I’m just gonna go ahead and put this in as I am sure this is not the last time I’m going to be in there and absolute worst case scenario if the gears die parts for these things are so cheap it almost doesn’t matter.
WOW man, just read this thread... I'm in the same boat. Just started my tear down, I got the whole center of the truck from tower to tower removed. Currently I'm a noob too with the house, wife, dog and newly added 16 month old. Talk about limited time! The little guy is a huge time suck lol but he's awesome and I can't wait till I can share the garage time with him. And you can never ignore the dog or he'll get jealous or sad. I'll head out to the garage at night and she'll open the door to say she's headed up and I'm like "I'll be up in a few minutes" she just tilts her head and gives me this look, like ya right. ?So between work, house, wife, and new puppy, I have very very little time to play with this thing.
I was able to get out to the garage for a little bit tonight – granted I am getting more and more involved in buying more more parts the further I take it apart.
I never expected to be anywhere near this amount of time, parts, work, cost but I want to make it the best I can and hopefully not have to tear it this far apart again for a long long time.
The rear end is done with RPM a-arms, techno shock ends, voltage tower, Eddie bearings, and diff with 30 K fluid.
So tonight I worked on the front end- rpm a-arms are in, Eddie bearings, voltage tower, techno shock ends, just need to reassemble the diff with 60K fluid, hopefully tomorrow. Using the HR aluminum diff housing, as I managed to break the stock front one already.
Since I want to wait till tomorrow to clean the front diff parts outside because of the smell of the cleaner, I thought I would start on taking apart the center diff and motor mount. I bought the M2c mount, and I am doing 500K fluid with Eddie bearings.
I don’t have the mental capacity to figure this out right now, so I am going to bed. ?
Send these pics to Horizon right away. Those difs look like they were put in on cock-eyed.OK. So I literally took the diff cup and held the outdrive in my vice so I could grab the pins with needle nose and manage to work them back-and-forth until I was able to remove them.
I then cleaned the parts so I could get a better look. Remember this truck had only maybe three battery packs run on it. At that point totally stock un-modified.
I can’t believe what I am seeing.
I thought that the fluid seemed much much darker than the front and back, but the condition of the internals is horrible.
No wonder I couldn’t just slide the parts out like normal, they are deformed and worn as is the case itself.
Can’t say I am happy with this at all.
If I break a part, then does on me fine.
But I can’t imagine how I possibly caused this on my center diff??
Does anybody else have any thoughts?
