Infraction Infraction 12s build time!
Got the esc mounted and soldered up!! Got these sweet orange battery straps as well. Getting really excited over here 😁😁😁. Time to get the receiver box mounted up!
Gorgeous build, man. That thing is going to be an animal. Can’t wait to see how that Max 4 does!
Thank you very much 😁 I agree, I can't wait to see how it does
Just weighed it and it's sitting at 19.5 pounds. Hefty boy
There’s a school of thought that the weight doesn’t really hurt and can in fact help with stability in a speed runner. I don’t think your rig will be too underpowered to handle it? 😊
It might be too underpowered.......might need to bump it to 16s what do you think?
I think if you add any more power you’ll need an Experimental FAA certification and a tail number.
On paper and not using the puny Zeee packs that are currently in the picture
12S = 12*4.2V = 50.4V
ESC = 300A max
Power = 50*300 = 15000W = 15kW ~ 20hp
Realistic 'good' Lipo will be in the 3.8V range and 300A max ~ 13.5kW
With Zeee packs, my guess would be in the 5-7kW range, as they are anemic at best.
Most likely, they will throttle the current to about 150A max and be at 3.5V/cell when they do. All that for about 10s and then throw in the towel.
Please get realistic with your Lipos. Would be a shame on this build if you stay with bottom of the barrel Lipos. Always ok for initial trials, but they will burn out quickly.
ESC = 300A max
Damn my puny zee's really tickled your pickle didn't they? First of all this build isn't for maximum speed, so my zee's for the most part do what I need. That being said they are used in my bashers and what not so it was the easiest thing to use before sinking a ton more money into lipos. I do plan on getting realistic and getting better and bigger ones.
