Astronought
Hey all! I was hoping that someone will be able to help me figure out what's wrong with my MMX ESC. I've got it running on my Kraton EXB with the Castle 2200kv 1515 sensored motor on the stock EXB 12 tooth pinion, a Castle 1515 motor cooling fan and I'm running it on 4S power only.
So it will run fine for a little bit, sometime as long as10ish minutes, but then it will randomly stop dead in it's tracks and repeatedly play the startup tone before counting out the cells and rearming. Then it will run fine for another few minutes and do it all over again. It doesn't seem to matter how hard I run it, how hot of day it is or how hot the motor/ESC gets it just always does it. I swapped the receiver from my Erevo into the EXB and it does the same thing even thought both recivers run fine in the Erevo. Batteries also have no issues in the Erevo. I've reset the ESC to stock settings, updated the firmware, really everything I could think of, so any help would be much appreciated! I've linked a video of the random restarting in action below (turn sound on in the lower left hand corner first).
https://streamable.com/52lhqk
