Arrma lock tight has costed me $500 in value with in 6 Limitless'
I have taken apart 2 V1 Limitless' and 4 V2 ones.
The amount of locktight they put on the grub screw that hold the pin in that hold the wheel hex on is crazy.
I have a spot in one of my monitors be cose of a tool breaking in half do to ARRMA locktight.
I have a pile of arms and driveshafts that I can't use or sell. because of that pin I can't get the driveshafts out. even after using a soldering iron and mini blow torch.
NOW I have a chassis that one of the screws that holds the motor mount in stuck 2 of 5 I torched one came out one was stuck. I got a EZ-out (screw extractor) set today and when I tryed to take the screw out even after over a min of troching "I broke the took" the tool achly broke, I guess you buy cheap you get cheap so if anyone know of a high quality set or option I need a #1 and anything smaller like a #0 or #00 (if they make that size). I take a 7/64 dril bit to try and just take the screw out so I can still use the chassis well you will never guess what hapened... I broke the drill bit! and the tool steal that was stuck in the head was almost imposible to go thought with a hand drill.
I like the Limitless from a user perspective and from a resale perspective, but I am tired of them, and I am debating if I should stop buying the Limitless or any metal chassis Arrma.
If anyone has any advice let me know,
TN-RC
TN-RC
