Notorious J
It's gonna break, so might as well send it!
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- On a midnight train to nowhere
- Gorgon
- Granite
- Notorious
- Typhon 6s
So after rebuilding my Typhon, I've been out just a few times making new passes. Been okay for the most part, but twice in the span of a week, I've had a total loss of control of the car from almost a stand still. The first time, I was just testing the set up outside my house to make sure everything was working. Car went about 20 feet and lost signal. I walked up to the car and tapped reverse, and the car shot away at full speed into a curb. Esc was destroyed, battery took a hard hit, and one foam tire was chunked. I went in and begun the repairs, first replacing the esc. When I plugged it in, my radio sounded an alarm saying there was low power to the receiver. I unplugged the PP and everything seemed fine. I checked to make sure no lines were broken on the PP, and used a volt meter to check the positive and negative leads. All seemed okay, so I plugged it back in. Same alarm. Figured it might be the receiver, so I replace the Radiolink R7FG with a brand new one that was in my Vendetta. Set all the parameters on the radio, plugged PP back in, and it all seemed fine. I made two or three night passes on this new set up, and seemed to be okay. Yesterday, I got out to try some day runs. First pass, everything seemed okay, but I only got up to about 90 mph before letting off. Let it cool down, and rolled out to do another pass. Got out to where I wanted to start and was making a three point turn to line it up. On the last move, the car went off in reverse again and could not be stopped. I've run this road dozens of times, and have made the same three point turn each time. I did not hit the trigger that much and I even have reverse turned way down on the esc. The car just started to roll in reverse at a slow speed until it whacked a curb. Broke an arm, bent both TLR suspension mounts and one hinge pin. I've been using PP for over a year now, but this all started to happen in the last week. Am I playing with fire here? Is it possible that the unit is damaged from my crash? I keep it inside the receiver box and use foam to make sure it doesn't move around. It's never gotten wet either. Please don't be the guy who says I should get a Futaba. Yeah, I know they're better, but I'm not spending that kind of money for one car. The Radiolink has worked flawlessly for as long as I've had it, and still had reception when I made my 141 mph pass. I just want to know if anyone using PP has had similar issues and what they might have done to resolve it. My next move is to remove it of course, but I'm pretty sure my runs won't be as good without it.
