Sorry bro, just my opinion ✌ it charges just fine, not my go to however.It's awesome, quit BS.. way better than a Hota or idst.. imo anyway!! I will never buy another one!!
If less than 3.75v per cell, I would "storage up" as per good practice. Every now and then if cells were >3.9v per cell I would "storage down" to 3.8v per cell. Bought a bd250 discharger some time back and have been using that since.Do you use it to discharge or storage charge batteries?
Symptoms here:What's the symptom?
The Hota has 2 independent channels, i.e. it will work fine on the other until it doesn't.
I assume you have done the reset and self test, it's part of the system menu.
I have 2 running and no issues. Hota probably builds all the other chargers, i.e. there won't be a difference in build quality. I'd buy them again.
I did love the 2 D6 Duos I had. When they worked they are great. Known to have the best Brand/ quality Internal Power supply. Just that the scroll wheel craps out , so it's hard to navigate the menu after a year of use, Both of mine. I recently replaced the first one with an ISDT K2 Air. Flawless. No failing scroll button to deal with. I use a 400w/24volt separate PSU, FWIW.That's a tough call. How long have you had the D6? I thought about a DC charger but, really doesn't make sense for me. I don't need that much power. Gens seems a reputable brand. Maybe give it a go?
I wonder if some contact cleaner would've helped the thumb wheel? I admit, the thumb wheel is my least favorite part of the S6. Seems Hota really likes the thumb wheel.. it's better (to use) than the touch wheel on the Spektrum S2100 IMO. Honestly, if a $150 dollar charger gives 3 years worth of service, I think that's reasonable. BTW, aren't Spektrum's "smart" chargers made by ISDT? Seems I've heard that.. anyway, buy what ya like I sayI did love the 2 D6 Duos I had. When they worked they are great. Known to have the best Brand/ quality Internal Power supply. Just that the scroll wheel craps out , so it's hard to navigate the menu after a year of use, Both of mine. I recently replaced the first one with an ISDT K2 Air. Flawless. No failing scroll button to deal with. I use a 400w/24volt separate PSU, FWIW.
>>>The D6 Duo is already "outdated" as chargers go, compared to the ISDT K2 Air. IMHO. One channel on my D6 also crapped out. Its a single channel charger now. For me, the new flavor of the month is my K2 Air.
Edited.
@SrC So I did just have a gander at the ISDT K2 air, definitely looks just like the Spektrum stuff. I don't have a D6 nor have I owned one, what do you mean by outdated? They don't charge Lipo batteries anymore? I've never been one to get sucked into the test tube for the latest tech anyway..
I didn't know there was a correlation between Skyrc and Hitec.. TBH, I didn't know Hitec was even still in business, LOL.The tech in the charger is ISDT but they aren't made by ISDT. It's like the difference between a Skyrc and a Hitec.
I say the D6 duo is outdated, once I started using the K2 Air menus. It is more stream lined. And creates a list of the most common charge rates you have used in the past based on the various packs you've been charging. for instance it sees a 6s pack and defaults to the last charge rate you charged a 6s pack. Same with 4s and so on. Same if just storage charging.
The D6 duo scroll wheel cannot be fixed. I disassembled one and no contact spray made it work any better. The scroll wheel is its main drawback. It's no longer a great charger years later. Better options out there now. ISDT is not garbage as some say. Do more research on the brand. They have their own R and D department. They are not a relable brand. They did create the Smart Battgo tech. But Spektrum/HH bought it for their own chargers. Don't let the similar screen of the Spektrum to ISDT fool you. That screen and menu is found on many other chargers. The F/W is different.
With my K2 Air, I can charge 2 6k mah 6s bricks from 3.8v per cell to full charge within 30 to 40 min. At a 1c rate. That's about as good as it gets. Both channels provide 6amps steadily until it goes to balance mode near the end of the cycle.
K2 Air is a simple push button for navigation.
The 2 line display chargers appear old in retrospect. Smart screen displays are where it is at. I pass on the 2 line display chargers these days. Old tech. My very old SkyRC B6ac charger does still perform however. A light duty charger for my small packs in a pinch. But it is very basic, compared to current chargers.
My Hitec is just whatever I had it set to lastGood info guys. Thanks. FWIW, I never said ISDT was junk, nor the Spektrum chargers.
My S6 has been set at 5a charge rate since day one, holds it too. No need to change anything regardless of what cell count I plug in, 5a and good to go. Same for storage, defaults to the 5a I set it to. The Spektrum S2100 does the same..
I say believe whichever helps put ur mind at ease,LOL. My packs tend to be all over from cell to cell with ir.. no matter to me. I know when a battery is out of whack by the temperature after use and false lvc triggers in the esc. In other words, I gave up on watching ir readings..buy cheap, have fun, rinse, repeat.Okay so I ordered an Ovonic X1 charger yesterday afternoon, arrived at 4:30 this morning on my door step
The price was hard to resist at $92. 100w per channel is just fine for me right now, and suspect I'll use this as my "traveling charger" for heading the beach, etc anyway. It's compact as well, so that helps. Later on I may invest in a Hota S6 or Imars.
The Ovonic menu system looks almost exactly like that of the Imars D300. Which looks almost exactly like that of my Hota D6+. Now it doesn't surprise me anymore that they are all made my Hota deep down.
Ran a few tests. Voltage seems to be pretty spot on, can't complain about about basically a 0.002v variance.
But IR during charging is showing different between the two. I know IR for these chargers is an approximation, but which of these would you believe? (NOTE the cell order is reversed between these two chargers) these were tested on the same 4s CNHL racing pack, 5 minutes apart.
The ovonic x1 is still listed at $92.OK, I've been reading the thread but as a newb I could use some help
Have a Senton brushed and looking to move it up to LiPo. Also thinking if I get LiPo and charger then I can stop resisting purchasing one of the on sale Vendettas and I'd just need to get some 3s batteries for it. Any good chargers on sale at the under $150 range (preferably closer to $100)? Seems a few of the ones recently noted as on sale are either no longer on sale or just sold out. Thanks in advance!
