Slevin’s Arrma Typhon 6s GT conversion build
Slevin
Pew pew!!
Military Veteran
Wisconsin
Kraton 6s, Typhon 6s
Here she is! Only missing the f’in RX!! I have no clue when that thing will show up. I’m seconds away from just buying 3PV because I know I can get Futaba RXs quick. My cap pack works as well. Thanks again @LibertyMKiii !
I did get the USB thingy to program the MMX 8s so I’ll probably take a gander at that tonight.
mid I pick up the 3PV I’ll probably do the signal booster like @jondilly1974 did for his. So cool!
A8047421-C453-43C2-A388-528A3CC41992.jpeg BF452DAF-F033-47C3-A101-237B397F23BE.jpeg
jondilly1974
Speed running rookie, 3D printing fool
Toledo, OH
Granite, Kraton 4s, Typhon 6s, Typhon 3s
I really like the green. My next body will be a similar green with a dark metallic grey and white combo. Not sure on pattern, but an equal mix of the three is my idea for now.
fpvmiller
Don't just bash...Mod!
Granite, Infraction, Limitless, Kraton 6s, Outcast 6s, Outcast 4s, Typhon 6s
Great build so far. Inspiring...to me at least. I like the truck style gt bodies but most (if not all) are sold out at delta plastik.
Slevin
Pew pew!!
Military Veteran
Wisconsin
I emailed banggood yesterday to see what the hold up was on my RX. About an hour later I received an email stating that it was just shipped lol! It won’t be here until mid June!!!! Ugh.
Lride Chart
Kraton 6s, Outcast 6s, Talion
Sucks on the Rx.
fpvmiller
Dang a month for rx? I just walked into my lhs yesterday to grab another futaba rx because online supplies are getting depleted. I won't need another one for a while so I am glad I got it. What rx are you waiting on?
Slevin
Pew pew!!
Military Veteran
Wisconsin
Sucks on the Rx.
Very much so
flysky bs6.
Im contemplating just buying a 3PV again.
Slevin
Pew pew!!
Military Veteran
Wisconsin
Not by the body but I took a sharpie and drew black lines around the windows and what not. Bad paint job, might as well have bad sharpie lines lol.
Slevin
Pew pew!!
Military Veteran
Wisconsin
Got my 3PV in today! However, I do not have any AA batteries!!!!!! WTF?!?!?
I’ll have to scavenge some from somewhere. Thinking my kids Wii controllers.
Slevin
Pew pew!!
Military Veteran
Wisconsin
She’s alive!!!
I did take it outside to test it. I need to raise it up a bit as the body was occasionally dragging on the ground and I totally forgot to loctite the wheel nuts and I lost two wheels lol!!
Other than that, I set the EPA and trim on the steering and will do some adjustments on the esc this weekend.
I started with a 15t pinion and will go from there.
LibertyMKiii
Resident speed junkie
Dallas TX
Limitless, Kraton 6s, Typhon 6s
If you are going to attempt the long range stuff and late power a range booster also, I'd get a LiFe for it.
Good thing you didn't get the 3PM like I have, it takes 8 AAs
Slevin
Pew pew!!
Military Veteran
Wisconsin
Motor temps during the above run were hovering around 120 to 130 degrees F. Not bad. ESC was around the same. Checked the kydex esc mount and it didn’t appear warped so that is good.
Slevin
Pew pew!!
Military Veteran
Wisconsin
Took her out today after letting the streets dry up a bit. Definitely not an ideal street as there was tons of junk on it but oh well.
I tried pushing it as fast as I could down this street and ended up going a bit airborn and sliding down the street upside down lol.
I didn’t have my temp gun to check temps. I def need to clean her out now lol. I also need to flip the motor fans.
Lride Chart
Well no going back now. How fast do you think it was going. Might need a wing.
Create account
Log in
GMballistic Hydro dipped a couple of Arrma Typhon parts for practice Paint and Body 2
jondilly1974 Typhon Arrma Typhon 3S New PB 130mph!!!! Arrma 4x4 19
G Arrma senton 4x4 3s shocks Suspension 2
jondilly1974 Typhon Arrma Typhon 3S New PB 121mph Arrma 4x4 23
