Most of em. Not all of them.Changed out everything for socket heads didn't ya.
I did but i wasnt able to get a good gripIs there any relatively cheap, easy & effective solution/ fix for stripped screw holes in plastic? Could I just squirt some super glue or something in the hole? Just curious
Nope hand threadedI can't say that I've stripped any! Are you using a impact gun but I feel ya..
I would have but not something as important like in a diffPut a small cable tie down the length of the threated hole then screw the screw in.
I have a solution that has worked flawlessly on any stripped plastic holes. Strip the tubing off of 1" of 8-10 guage wire, cut it and then twist it lightly. Place it in the stripped hole and insert the screw. It's easiest when there's about 1/8 to 3/16 sticking out of the hole. The wire begins to spread as soon as you start turning the screw and fills all the voids. You can snug it to ~90% as tight as the original, and will hold just fine. Same applies for stripped metal holes. It's the same as using a helicoil. I have not had one failure using this process, and I use it quite a bit.I did but i wasnt able to get a good grip
Nope hand threaded
Seems like that would work really well for the hole in the a arms where the mud guards go. Getting started with the "feel" of tightness of everything still. Screws into plastic is still a "sensitive" subject w/ me, just trying to feel tightness without going too far (Sorry about the dad joke)I have a solution that has worked flawlessly on any stripped plastic holes. Strip the tubing off of 1" of 8-10 guage wire, cut it and then twist it lightly. Place it in the stripped hole and insert the screw. It's easiest when there's about 1/8 to 3/16 sticking out of the hole. The wire begins to spread as soon as you start turning the screw and fills all the voids. You can snug it to ~90% as tight as the original, and will hold just fine. Same applies for stripped metal holes. It's the same as using a helicoil. I have not had one failure using this process, and I use it quite a bit.
It's the one thing that everyone needs to learn about working on rc's. When they create a new plastic part, the holes are unthreaded. When they insert the screw, the thread is created and is usually very tight. When we take that screw out, we are deceived into believing that the screw has to be super tight when putting it back. It takes some time to adjust your mindset that once it's snug, that's enough. I use an electric screwdriver now for most of my rc repairs. I hold the button very lightly when screwing into plastic so the second I feel resistance, I let go. I then take out my hex driver to test to see if a light turn is needed, but usually I get it right the first time. There's few things worse than stripping a hole and not being able to run because of it. That's why I cam up with the wire hack to save any that get wrecked. Someone mentioned the zip tie trick, but I found that this option expands the hole too much and won't last. The wire hack allows a small amount of metal to circle the original threads of the hole and fill them in.Seems like that would work really well for the hole in the a arms where the mud guards go. Getting started with the "feel" of tightness of everything still. Screws into plastic is still a "sensitive" subject w/ me, just trying to feel tightness without going too far (Sorry about the dad joke)
It's crazy what big tires do to the diffs.im running stock plastic axles,diffs everything on crazy power with no problems over 6hp 116mph on 98mm grpsStripped another CVD on the Bigrock running 4s yesterday. That's both rears now from the used set I bought from another forum member. Replaced it and had an awesome bash and then checking rig over after noticed my rear diff is locked up so may have killed the internal gears. View attachment 214546
2 hrs after posting about NOT tearing diffs up.stripped a rear on this vid.bigger,heavier,lwb with noto body.It's crazy what big tires do to the diffs.im running stock plastic axles,diffs everything on crazy power with no problems over 6hp 116mph on 98mm grps
I want to design an rc car that uses only socket head screws.Most of em. Not all of them.
Hillman has some high quality products. That's what I used on mine where I could.. even button heads are tough as nails.I want to design an rc car that uses only socket head screws.
G Pit takes another victim
Lost signal. End result... 4s lipo dead. Everything ejected. Stripped it down and tossing it.
Probably so. With the nb4. I can't even reach the steering one handed. Since it's farther away.Imagine if you had one of them singular hand thumb steering jobs, it would probably be a pancake.
