- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
I wonder how much more room a 36mm can would give ya???enough for north of 1 to 1 making running a lower kv motor possibleMy other vendetta with 28/34 doesn’t allow me to run the bearing guide for the driveshaft so I don’t know how it will hold up
View attachment 199792Will update pictures tonight. Worked on making a couple more spools for different gearing options.
Current 4s gearing will be setup geared 32/32 which is the smallest I can run as the motor interferes with the bearing guide for the driveshaft. Geared to 187mph and hoping to net a 150 pass with that setup.
Built 34, 36t and 38t spools:
so for 6s I can run 25-28t with 36t spool
And on 8s I can run 20-24 with 38t spool
I really don’t know how this 2950 motor will do on higher voltage as far as heat and power output. Even tho it is rated for 8s I think the sweet spot with balancing battery weight and power will be my 6s runs on this car.
