- Maryland
- Infraction
- Limitless
- Mojave EXB
- Senton 3s
- Talion
- Typhon 3s
- Vendetta
After having an awesome month or so running my first vendetta, which it currently regeared for 150+ come spring,
I had the itch to start to build a second one with some different ideas from the first car
Part list:
Xlx2 setup w/ parallel qs8
Tp 4070scm 2950kv
Lwb 3s chassis with vendetta towers
Exb metal front and rear diffs (20million weight)
Typhon 3s adjustable wide arms
Limitless rear shocks (with rubber hose to limit travel)
Vendetta front shocks(with rubber hose to limit travel)
Savox servo
Emp 6s chassis battery trays
Custom carbon bits: to adjust front and rear droop on control arms, and ESC mount
Custom Carbon fiber tower to tower brace
Full carbon delta plastic body
Bsr purple or xx pink foams
Custom mod 1 spool
Vendetta front splitter
Vendetta rear diffuser
Goals are lofty I have no personal experience with the scm motors yet,
But I would like to break 153mph on 4s which is the fastest 1/10, 1/8th chassis 4s record I’ve seen. 4s runs will be with two 4000mah cnhl 4s in parallel geared 32/32
Will then run 6s with parralel 4000mah cnhl batteries geared 25/40
Most stuff mocked up, was trying to figure out a way to mount the motor and ESC without using motor lead extensions but I ended up having to extend them slightly
ESC and motor mounted in place with wires.
Custom made carbon pieces for bottom of chassis and esc mount
Part list:
Tp 4070scm 2950kv
Savox servo
Custom mod 1 spool
