Camaroboy383
Invention is the mother of necessity!
ArrmaForum Fan
Hospitality Award
- Connecticut
- 4x4-Mega
- Felony
- Outcast 4s
- Outcast 6s
- Outcast 8s
- Typhon 3s
- Typhon 6s
Ok, so based on the video I posted wouldn’t that lead to the front diff? The front keeps spinning while brakes are applied and spin faster.
I will check the front diff again and also the input cup.
I don't know..as stated I can not see the front output cup on the center diff.. so you would need to check it again but pay close attention to which spins faster..
The power will follow the path of least resistance..
And you have to pull the sun gears, no choice if you want to see the output drive pins.. the center tiny gears are planetary gears.. the sun gears are the large ones on each output cup shank..(each side of the planetary gears)..
