Without locktite my M2C hexes come off easy. Pins also, maybe you shimmed the hex too tight? If the pin needs quite some force to get in the hex it’s to tight.
Add a bit of bearing grease (about 1/3rd of the bearings) instead of oil. Oil slowly leaks away/ dries leaving your bearing without lubrication. Although without grease and a drop of oil it feels super smooth, it’s good for speedrunning (no dirt and usually very high maintenance level; oiling bearings every pack/run), for offroad conditions and less maintenance not so good IMO.
