Chris Lane
- Kraton 8S
My nitro, doesn't like the temperature change.. ??
Not sure if there's a fear in travel or extension, but seemed to go well on this first time out. I'll watch and keep you posted.I am still leery of doing that swap. If @Thomas P said you shouldn't, I tend to believe him ???
Ok great I have a whole front end - dog bones, cvds, knuckles - kit from Jenny’s. Bought to truggify my typhon. Just need to buy a typhon yet. ? guess I’m either doing things backwards or a good pre planner. Verdict is still out. thanks @Notorious J for the quick reply ?Straight swap using front cvds. You can buy full axle/shaft sets from Jennys Rc very cheap.
I've been running front cvds in the rear since December 23rd 2017 and I have not had any issues.Not sure if there's a fear in travel or extension, but seemed to go well on this first time out. I'll watch and keep you posted.
??????The printer probably typed that post.
At first glance I thought they were f-ed up turtles ??Are those the ProLine Belted Trenchers or the Sweep Terrain Crushers?
Smoked a couple sets of turkey tits? Just for employee meals. Easy stuff. Brine 4 days, air dry, smoke with pecanwood til 160F internal.
Shoehorned it in there... almost done now, trying to get the fan wires and whatnot on the esc side to lay somewhere safe with enough slack to not break or unplug. Makes me miss nitro a little bit. 6V pack, no fans, just a receiver, 2 servos, button it up!Been replacing the chassis on my ERBEv2 the past 3 days after work. Trying to come up with better ways to do some things (how I have the roll bar installed, skid plate, rear brace I made, installing more upgrades from my v1, etc.), so it's taking way longer than it should. Currently waiting on some 20awg silicone wire so I can install a 10A castle bec to take the load off the esc. Not sure why, but the power wire they have on it is about 4" and the servo lead is like 12". It's not waterproof, so I assume people usually try to put them in a receiver box, so why they only give such a short wire lead for input is beyond me. I'll be desoldering both leads and adjusting accordingly. Also have a probodyrc body to cut/install for it.
Update. Needs work. Shakes and shimmies at higher speeds. Will need to play with the gain +\- and see if that helps. On the fence on wether it’s a good spend or not.Installed the SKYRC GC301 gyro from RCJuice in the PLMT4x4. Not much room in it so put it on top of the receiver. Wire management is a must. Zip tied to outside mug guard. View attachment 51844Seems to worked on the bench. Will test it out later today.
That’s typical of most gyros. Your gain is just too high.Update. Needs work. Shakes and shimmies at higher speeds. Will need to play with the gain +\- and see if that helps. On the fence on wether it’s a good spend or not.
Cool thanks for the info.That’s typical of most gyros. Your gain is just too high.
Are those BSR foams?Finished the body for my drag senton today. I'm trying to get it below 1.9 sec in 132ft. I'm currently around 1.95 consistently on 6s on a no prep surface.
