m4inbrain
So.. I'm a bit out of the loop.
I'm sorted in terms of servo i think, i'm slightly puzzled in regards to ESC/Motor. I intend to run it on 6s exclusively.
I like the 1717/MMX8s, but admittedly, it's quite steep in price (it's $516 over here) - and probably quite some overkill. I was interested in the Hobbystar 4092, which you can't get anywhere in europe (or the US for that matter?) as it seems, so that one's out too.
I don't mind spending money for quality, but at over $500 for a (in my case) 6s system, i'm not sure if it's a bit overkill. What would be other "go-to" combos that manage heat at least decently? Max6/4985 combo, i've read somewhere that people got temps up to 190F, is that indeed what i'd have to expect (and, would the motor actually mount to the motor plate without modification somewhere)?
I was always humming and awing over the Kraton, but with the EXB the time has come to pull the trigger. Could someone point me to the best 6s setup, and maybe the second best too - prior to this truck, i've only ever run 4s and 8s RCs, so i got no idea? Bonuspoints if the suggested motor is compatible with a fan shroud.
4092 1650kv would be an option, Surpass Rocket (seems to be very similar, if not the same as the Hobbystar oO)? What pinion would go with that, 21t?
