How do you find the lipos on Banggood? It’s confusing as hell!!!!Too small on both counts. The EXB has more extra-strong parts and more aluminum. That means more weight so it needs a bigger motor with lower KV and a higher amp rated ESC than the RTR 6S trucks. If you are trying to go as cheap as possible I think a Max8 combo will be the minimum. You will have to buy a SMALLER than stock pinion, but it's close to the RTR electronics.
Hobbywing EzRun Max8 v3 150A Waterproof Brushless ESC T/TRX Plug+2200KV Motor For 1/8 RC Car Parts
https://banggood.app.link/tqXabScgscb
But if you want it to run well and not worry about overheating and be able to use bigger pinions I'd go with the Hobbywing Max6 1650KV motor combo.
I just got the EXB and the Max 6 1640 I’ve got the standard spur on a 23t pinion ( I don’t think it will fit a bigger one because of the screw holes in the M mount) and it’s running fine. It’s quick got loads of torque and it’s not overheating in any wayIt's actually great on 6s, 8s will be mental . You just need to gear it up slightly for 6s, I would recommend a 20t.
Still got crazy amounts of punch (I’m on 3) and you can pop wheelies at any speed. I just wish I could get hold of an Arrma wheelie bar plus I think I’m tempted to get the Talion wing as it looks way stronger
I am looking for a a decent center mount brace F+R if there’s any suggestions rather than the Chinese stuff and has the right slots cut in so the rear is a direct fit?
